Oil pan cooler???
Jtreece
Kansas
Has anyone ever used the oil cooling system from Ford Performance Specialist out of Atlanta Georgia?
The kit sells for $800 and comes with a big 12"x12" B&M Super cooler, rotary vane oil pump, lines, fittings and adjustable controller. To install the kit, the hose fittings must be welded to the outside of the oil pan.
Basically its sucking hot oil out and running it through a cooler under the pickup and pushing it back in.
psmike
Calif
HMMMM I looked up ford performance specialist.. an first thing that pops up is a very bad yelp review.. still cant find the site your talking about.
Mesa, AZ
I dunno man, seems like more **** to **** up. Plus, ive noticed there seems to be a sweey spot for the best performance, oil temp wise. Seems to be around 180 or so. That may also cause oil pressure issues. If it sucks too much oil, and starts to starve the pick up, bad stuff will happen.
79jasper
skiatook, Oklahoma
I guess a question could be, why do you feel like you need one?
Put that money towards a oil cooler relocation kit. Unless you already have one...
Sent from my SM-G892A using Tapatalk
Jtreece
Kansas
I saw the bad reviews as well, I didn't know if anyone on here has used one. From what he said it doesn't cause pressure issues and it comes with a controller to control flow pressure. All it basically does is recirculate and cool oil. I never felt like I needed one I guess just really asking about it. My goal is going with BPD external soon because my new oil cooler of 2 months is already getting close to the magic 15 degree mark. Hell today I was at 192ect and 202eot when its only 68 out and when its 95 I'm at 199-202ect and 212-215eot
