Dieselboy.
Having an odd issue.
Just installed a mech oil pressure gauge in the reservoir. Cold idle is 30ish psi. Warm idle is 11psi, cruising is 20 and it wont go any higher.
I can mash it from 2000 RPM and go all the way to 3400 and my Oil pressure gauge wont go over 21ish psi.
Anyone have any ideas on this ? I know its a pressurized system all together so really tapping in at the reservoir or off the filter housing shouldnt matter. It should see the same pressure, no ? What would cause my low RPM oil pressure to be fine but not move past 20 ?
