Old or broken TS Chips
woodduck97
Maryland
Buddy of mine has a TS chip that is in working condition and needs the peice that plugs into the PCM. Anyone have one that does not work laying around?
Big Bore
9000ft in the CO Rockies
You mean he needs the pin connector that's part of the chip? Because the chip plugs directly into the PCM. If the chip is missing the connector, I'm not sure that qualifies as "working order". Is the pin connector damaged? Otherwise I'm wondering if he has a switch and cord, and needs the chip.
Edit. I see you have Gearhead tunes so I'm assuming you know all the above, I'm just looking for clarification.
woodduck97
Maryland
The pins are messed up on the connector that plugs into the PCM.
golfer
the chip plugs into the PCM...I have no idea, as to what you are describing...
PCM-chip-cable or..in reverse..cable-chip-PCM
you might be better off using pictures.
woodduck97
Maryland
The circled area is the peice that is needed. The pins inside that is what is messed up.
