Power Strokes
6.0 Aftermarket
One touch up and down?
[QUOTE="GregW, post: 1496678, member: 23019"] You can see the wiring instructions here: [url]https://pdf.ampire.de/directed/535T_englisch.pdf[/url] It's relatively straight forward. You wire it to constant +12v and ground. Then cut the wires between the switch and window motor and wire this in line with it. The rest of the wiring (for alarm triggers) can be ignored if you just want to use it for the one-touch feature [/QUOTE]
C
Latest: Cazador
Today at 1:46 AM
Sunrise Ford Parts
Lower coil spring pad bolt
Latest: KBMKVIII
Yesterday at 7:14 AM
Latest: 6.0 Tech
Yesterday at 12:34 AM
7.3 Aftermarket
B codes vs hybrids
Latest: Charles
Monday at 9:54 PM
7.3 Aftermarket
B-Code VOP
Latest: Charles
Monday at 9:29 PM
7.3 Aftermarket
DEEZUZ
6.7Bison
Power Strokes
6.0 Aftermarket
