P!P V8.02 lv4 Testing
jwalk09
VA
anyone having an issues with boost flaring up at slight throttle increase? lvl 2 v8.. only have a few miles on the install..
Haven't noticed that. How much are you talking ?
brock1129
seems to have a flare around low throttle 10psi and then jumps to 15... ive been having some pump related issues and cant tell if its the tune or pump
hunter.b
I ran that tune for about a month and didn't see that either.
Mechcont
Mine does it when the oil temps are below 110ish. The boost will jump from 7 to 15psi instantly but it only happens when it's cold I just feather the throttle and it goes away.
O4ep3civ
How much boost are you seeing on the updated lvl 4?
Parker brothers
michigan
I've seen 41.3 pounds of boost on this tune using my SCT livewire ts.
I really don't know how accurate that is but have seen it a few times.
FordPSD64
San Antonio, TX
yes, I figured it was the update to windows 10 on the laptop. But still can't get it to load..
Mine updated the firmware and something else but the last update I get this
Also the damn SCT app shows like the SCT is never plugged in and if I try to do anything I just freezes up and I have to close it. Is awfully frustrating.
FordPSD64
San Antonio, TX
Try a different cable into your computer. I've been fighting this thing for hours, switched cables and bam. Works fine. The other one seemed fine because it would turn the SCT on when you plugged it into the computer. But would never show it was connected on the computer in the SCT program. Worked fine with a different cable
David1089
Louisiana
I was also having trouble with the updater. I uninstalled the entire program and went to Sct and downloaded the updater again. And it's working like a charm. One thing. You may have to go into the properties and maximize the view to see everything on the screen. For some reason Sct has disabled the button in the top right hand corner. Hope this helps man.
Mechcont
I had a lot of problems with the software using Windows 10 but I was also using Windows 10 on a partitioned Mac. I had to wipe all of the tunes off and reload them individually using Win 7, all good now.
BIG JUICE
Valrico FLA
had same issue and pip was no help( in their defense they told me only time seen my issues, tuner was not updated). called sct and they remotely logged into laptop and fixed issue, was not updated, like pip said. even after it said it was. really weird. I am good now, just aggravating being stranded. laptop would not update tuner. And did it wirelessly, but obviously that didn't take.
