P0269 code, Injector or low compression? HELP
I decided to check the ol' SCT today and here we have P0269 contribution/ balance pop up. Engine and injectors have 27,000 miles on them. Now my RCD 175/75s (poor injector choice) have been starved at 0psi fuel press a couple times a while back before because of electrical issues with the Fass. I did an injector buzz test and all 8 checked out fine, but I suppose they could still be bad? I wouldnt think I'd have low compression with only 27 thousand miles but i guess anything is possible?
Heres some details:
Exhaust haze at idle, but clears up once engine is warmed up, maybe this is normal for large injectors?
No bucking or choppy power delivery
Choppy/misfire idle SOMETIMES while AT OPERATING TEMP
FICM did read as low as 46v on sct gauge
icp never went below 790
Injectors have been starved a few times at 0psi fuel cause of fass shutting off
What should i do next? I do plan on having warren repair/ turn my sticks into 205/30s, but should i do more testing instead before i pull the trigger? Just not sure what my next step is in fixing this issue?
Heres some details:
