P0602-C code.
Lubbockguy1979
Lubbock tx
Was messing around with forscan and set this code off. What can i do to clear or resolve the code? Trucks runs and drives but has a cel illuminated
Sent from my SM-G975U using Tapatalk
Lubbockguy1979
Lubbock tx
P0602 Control Module Programming Error
What were you doing with forscan?
I had seen a screen that showed the speed limiter under the pcm on another guys post. So i guess i relearned the pcm expecting to see it in a sub menu. I then realized they had a update on forscan after that and updated.. then found that gave me the as built tables i was lookong for. In the tables the speed limiter portion was only to lower the speed but i saw a option that i thought was turning on the operator comand regen so i enabled that. After doing that is when i noticed the code. The code will not clear so far.
Lubbockguy1979
Lubbock tx
Guessing im going to have to have it reflashed with ids as i havent found out a way to reload from as builts yet.
wreedps
DId you ever get this fixed? If so what did you do? I have a 2015 Platinum with code p0602
