P1211 need help
g2outfitter
Trucks a 97 7.3 F350 auto 4x4. 167k
Yesterday I had 160/30 injectors installed, efuel, d66 turbo,bellowed up pipes and dwn loaded tw tunes custom to my hydra. Truck run great but if I get on it any it throws P1211 code. Im thinking hpop, but was has me stumped is if I put back on stock programming it still does it. Never did before.
If I drive real real easy it doesnt come on.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
g2outfitter
Yes fuel pressure is reading 65. Ty not sure whats your question.
TyCorr
Injection control pressure. Its the measure of the high pressure oil pumps output.
After you answered that I wanted to know what icp is commanded by the tuning when it pops the code.
g2outfitter
Code just say icp is either high or lower than required
g2outfitter
Yes. Guess I have a new purchase in near future.
Justin@DP-Tuner
A good way to test this is to hook up a scan tool and watch ICP and IPR duty cycle. Normally, tuners call for 2600+ psi ICP. If you see ICP drop below comanded and IPR duty cycle go over 65%, that is why you are getting a P1211. If could be caused from a weak pump, or too much PW in the tune, or even a combination of both.
g2outfitter
Thanks Justin, I believe its the pump. On my Cts it is showing high 50's so I bet for a split second its going over 65. I have a new pump on the way.
Justin@DP-Tuner
No problem. Report back if that fixes it, to help others out in the future.
g2outfitter
Well new hpop. Lines and ipr valve were replaced and fixed my P1211 light. Thanks for the help. Now if I can only fix my door locks
