Lubbockguy1979
I just installed a jvc kw-av61bt deck in the truck. At this point I've got the steering wheel controls, mic and everything pretty much wired. All I have left at this point is working around the parking brake. I'm not sure exactly how to attack this as I appears to need a voltage signal. Does anyone know what I'd need to do as a work around? I assume I won't be able to simple wire it up to a constant line meaning it will have to have some sort of a brake in continuity to function. Also I am starting to look for a decent back up camera. I don't really need 1080p quality but decent function would be nice. What is something moderately priced that functions well? This will likely be mounted to the parge pipe rear bumper as well if that make any difference since I no longer have stock bumpers. also what are the possibilities of potentially using a front and rear camera with some sort of toggle switch to switch inbetween the different cameras?
