*PART OUT* 2005 F250 eclb lariat 4x4 auto diesel
Status
Not open for further replies.
Wired1
I'm looking for the tail pipe hanger bracket. The one behind the rear tire. PM a price shipped to 87124
Txpsd
I'm wanting the entire dash along with all the air ducting behind it. Basically I am wanting to swap my 01 dash for this one, so I'll need pretty much everything. I realize you may have sold some of it, so just let me know. Zip is 73120. Thanks!
1965
how about the fuel filler pipe and hoses to tank zip 23111 va thanks bobby
java
Texas
Does it have the OEM trailer brake controller? Shipped to 78586.
patrick@WDI
Injectors & seats shipped to 16327
Sent from my DROID RAZR using Tapatalk
pm sent
the dash has a few kinks in it and obviously the airbags went off. the main drivers bezel is in good shape tho.
Have the rocker switch panel?
the switch panel on the drivers door? or what do you mean...
pm sent
pm sent
i want to keep the engine together at this point-if no further interest, i will separate
Dash cap on the passenger side???
pm sent
how about 1500.00 shipped for the pair of axles?
Thanks to the psa family-this truck is pretty much gone:
this is what i have left...
E-S-O-F Transfer Case
Pair of axles (includes draglink on the front and auto hubs)
5R110 Transmission 4x4
Front and rear driveshafts
radius arms
centre console (tan w/woodgrain lid)
sliding rear window with Motor and Seal
drivers dash bezel (black and woodgrain)
drivers door switch panel
two sets of 2" rear blocks with u-bolts
overload spring and block
tailgate
2x rear chrome bumper (one w/sensor holes, one without)
auto hub vacuum pump
abs motor
master cylinder
frame fuel pump/filter
lower dash with drivers glove box (tan)
in-dash cupholder (tan-not broken)
factory trailer hitch
stock coil springs
steering gear w/pitman arm
Wheel nuts
100k mile 05 6.0 studded and deleted motor
taillights with bulbs and pigtails
need everything gone to make room-the only thing i need to get my moneys worth on is the motor because it runs flawlessly and was studded properly.
pm me offers on the rest. thanks.,
jdc753
Norton, MA
Do you have a good picture of the dash bezel wood grain/black?
and how much shipped to 02766?
i also have:
degas bottle
cab light harness
pm me your number and i will text it to you. Do you need the switches in the dash also?
only drawback it has tempered glass stuck to it from when the window broke.
jdc753
Norton, MA
PM on the way, how bad would the glass be to clean off? I wouldn't need the switches but AC vents would be good. Need something that I can return my truck to stock if it gets sent down the road.
I would like to keep the engine complet at this time
Status
