Parting out a 94.5 7.3 Powerstroke engine w/162K miles. Low pressure oil pump failed, engine lost oil pressure and was then parked on the side of the road. Injectors and Hpop are gone, still many good parts available. Located west of Portland, OR (zip 97106). More parts pics available upon request.
Parts available:
Short block $400
Heads $200
Exhaust manifolds $150 both/$75 each
Up Pipes w/collector $100
Turbo $200
Oil Pan $125
Oil pickup tube $25
Oil Cooler (both ends & center section) $125
HPOP oil lines $15 each
Fuel lines $15 each
Fuel line w/fitting to fuel pump $20
Fuel Pump $20
Valve covers (drivers side has one small dent) $40 for both
Valve cover gasket $20 (only have 1) $20
Intake Y pipe $10
Motor mounts $40 for both
HPOP oil reservoir $20
Timing Cover (has a small groove worn into it from LPOP, will need repair work done) make offer
Water pump pulley $5
LPOP housing $50
Parts available:
Short block $400
Heads $200
Turbo $200
Oil Pan $125
Oil pickup tube $25
Fuel lines $15 each
Fuel Pump $20
Intake Y pipe $10
LPOP housing $50
