PCM
blageurt
T.Dot
I need a good DPC-202 PCM ...some examples are TEE5 , TEE4 , TEDO , TEDI etc. etc. basically 7.3 with E4OD code AA Injectors... 94-97 OBS Non Cali and 95-96 E series
thanks
Strokersace
Towanda, KS
I'm pretty sure I have an NAW4 in the garage if you're still looking.
Worked fine, I'd just swapped it for a TDE1 for shift strategies.
Got it of the 7.3 game a while back and have no use for it now.
blageurt
T.Dot
Big Thunder ...Thanks alot but that is a split shot PCM....like the Cali models in your world
blageurt
T.Dot
ACE....Thanks... I need to determine if the NAW 1-5 series are ( AA or AB) ... I will check on that... I need the former .... I will buy it ....thanks again
blageurt
T.Dot
Yes you are correct...I just had it confirmed by a Master Diesel Tech...So... I need it shipped to Postal Code L4J2V7 , Ontario , Canada...PM me and we can discuss Details ....thanks again
