I put the kit on my motor while on the stand.. I have not got the motor in the truck yet...I still need a couple more parts... every thing fell together perfect and looked very nice..the kit moves the turbo forward and up to help clear the cowl better...I had my 467 with the race cover on there and it seems to fit very nice... hard to tell about the hot side pipe till I get the motor in the truck..the kit included the air intake tube and filter,the down pipe,the up pipes..cold side IC pipe, a adapter to use with your stock hot side pipe...and the Y pipe..it has a cast mount with a port in each inlet for EGT gauges or a BP gauge...also come with braided line,turbo blanket,plenum inserts all the boots, nuts,bolts washers and clamps you need to put this together...you can also get just the mount with up pipes and make your own pipes....
