Pics of T4/T4i turbo mount pics
CSIPSD
Bend, OR
I 4" down pipe will cause no issues...
Is the outlet a true 5" or just where it necks out at the down pipe connection?
ryanss22
upstate central ny
Its not right in front of me, but I'm thinking since its the v-band outlet with a 88mm turbine wheel, its only 5" at the lip ends... If I remember correctly obspsd was having back pressure issues with running a 3"dp on his s475... Maybe he'll chime in...
CSIPSD
Bend, OR
I could see a 3" down pipe being an issue, but I really dont see a 4" being that much of an issue if any. More then likely its a 4" or 4.25" right at the wheel...
Magnum PD
VA
Gonna have to check them out later. I cut off a small piece of an up pipe to see how well it will fit around one of the flange opening. About a 1/4" bigger than it needs to be to fit perfect.
IDP
Believe we are adopting hoodstacks in 2.6, should know by next month.
ryanss22
upstate central ny
Yes, I was at the meeting a week ago and paied my membership.. I'll be there febuary voting to for hood stacks in 2.6.... Might still try to make a 4" DP since it will see some street use.
ryanss22
upstate central ny
I bought the Irate kit and his has bellows.. If it were me and I was making my own I would def add some bellows, gives the up pipes just a bit more flex with the high heat.
