silverpsd_06
Needing some ideas for a oil drain off the atmosphere turbo any ideas would be appreciated guys it is too low to use the valve cover, the charger sits about three inches above where the cps is in the motor. I would like to avoid drilling a hole into the oil pan if I can but if it is unavoidable then ill do it.
Thanks in advance this is one of the last things that has to be done to get the damn thing on the road
