possibly retarded question
Magnum PD
VA
If you have a turbo that is cleaning up all the fuel, then put a bigger turbo on, wouldn't the affect be minimal?
Cota
With the 38r I could hit 42 psi of boost, I never measured back pressure though,
With the 42R I could hit 52 psi of boost, stay 1 to 1 up to about 45 and at 52 psi of boost I'm about 65 psi back pressure.
ken6881
my only thought if it had a looser turbine housing it would have less back pressure freeing up a few ponies.
Magnum PD
VA
The 38 probably has some back pressure.
Put if you put a 38r on a completely stock engine, I just think you will see much improvement.
