Post injection to help spool..?
Kind
I came across a posts on compd talking about using post injection in the lower rpm ranges(I'm assuming below 2500) to help get fix vane turbos to light easier. Has anyone tried this with a 6.4 in MCC? I was looking at it but I have no idea what numbers would need to be used.
TD-5
British Columbia Canada
There is very little in the MCC files dealing with Post injection, There is an activation map, a couple of post injection on/off tabs as well as two rpm tabs, That's about it. I would suspect one or two of the configurations in Injection Timing & Mass fuel Commanded probably relate to post injection. 2 & 3 would be a best guess, only because H&S doesn't alter those timing configuration tables. But unless you know for sure, I don't see any way of changing the post injection characteristics.
Kind
I did turn it on and set all the numbers to 1.00 in the activation map but I didn't like how it ran so I turned it off.
drunk on diesel
I think I'm going to play with this... I think the key is re-scaling the X & Y so you're actually focusing on exactly where you're needing/wanting it vs. applying a blanket post injection event
