ja_cain
- Joined
- Aug 10, 2013
- Messages
- 4,597
- Reaction score
- 2
Trying to help out a buddy of mine. He has a 00 with with 180/80's, TS Chip and tunes from ********. PCM is NVK4. Truck was running real rough and idle was jumping all around. It had a bunch of codes on it when I scanned it. Some of them made me think the IPR might be having issues but did not have a chance to run it down the road and look at all the usual suspect parameters related to this. I had him pull the connector once he got home and sure enough there was oil on the connector. That helped some but it still is running like chit. He thought maybe the TS chip wasn't making contact, so
he also had the J3 connector re-tinned and it is still running like chit. I have posted a pic of what it looked like before. There was definitely a fair amount of copper showing and pin 3 actually looks damaged. I don't have an after pic yet but will post one up once he sends me one. It may be that re-tinning may not have been able to fix the 3rd contact and that is still causing the issue.
I told him that I would post up the info and see what you guys think. I would like to see if I can source him a replacement PCM to try out. Looking on ebay they seem to go for around 6 to 7 hundred. I think that is BS. If anyone has a cheaper source, I would greatly appreciate the info. Here is a pic of the PCM code and the J3 connector. Thanks in advance for any help guys.
Oh, one more thing, I told him to just have a mild tune flashed to his PCM once he gets everything figured out. Seems like a no brainer, in case the chip craps out.
Justin
Justin
