Power steering filters
Mini-Stroke...
NC
Does anyone use them? If so, where do they mount and what brand/size did you use?
Also, does it work, and where did you get it from?
Thanks
ytee
I have not used one but I believe Tymar use to sell just a little in line filter for both power steering and tranny.
Chris
Tom S
I also think magnafine makes a power steering filter. If I ever change my set up to add a better cooler to the powersteering I was thinking of adding one.
ytee
Thanks Tom Magnafine was what Tymar use to sell that I was talking about.
Chris
Tom S
I know I have installed a few remain powersteering pumps that wanted a filter installed with them. I just flushed the system using the pump instead. I use an air ratchet to run the pump when doing it.
Mini-Stroke...
NC
Thanks for the info! I blew a hose the other day and the reservoir was full of crud and it got me to thinking
Also, what size is the return line?
Tom S
Not sure on the return line but I would flush the system. I put a cap on the reservoir nipple and extend the return line to a container and then run the pump with an air ratchet and an allen adapter.
Tom
