what a mess
ok guys my truck was down for 6 months and about 3 months ago I started it up tried some things and at that time I had power steering and now I have none so I jacked the truck up both front tires off the ground and I can move the tires freely with my hands so then I check the steering wheel it moves freely also so then I started the truck tires off the ground still power steering works fine then I put a little pressure on the tires and it still worked fine but when I put it all the way down it works a little in the strait and barely turned but when trying to turn in all the way either way it get very very hard to turn and it seems like it gets worse the more I try to turn it back and forth and help would be awesome because it will get expensive throwing money at these parts any ideas advise would be awesome thank you
