Strokersace
So I'm in the middle of redoing alot on the truck. Motor is currently out with some changes being made to the stuff I rushed on in the winter/spring 2010 when building it the 1st time.
Had a major problem with keeping belts from squeeking or coming apart since getting it going. Was removing the power steering pump the other day to clean and paint the bracket and noticed that the shaft has about 1/8" play in and out.
Is this normal? This one came off an 02 and installed used last year when I did the hydroboost conversion. Checked the stock one I pulled (still have in a box) and it has the same play.
A couple of years ago when it was all still stock, I had it chew up a belt out of nowhere. Then in the spring of '10, I converted everything to the SD brackets and setup. So both brackets and all accessories are now out of SD with the Alt being on the drivers side and a/c on the pass. So none of the old stuff was used again. Still had belt issues after switching to the SD stuff. Went thru 3 belts due to massive squeeking (2 NAPA and 1 Motorcraft). The last one ended up chewing off a "rib" this past winter but didn't completely come apart. It's like it has a pulley or somethign that isn't aligned perfectly and the belt "jumped".
Wondering if the play in the power steering pump is normal or if that coupld be causing my belt issue?
Thanks guys.
Thanks guys.
