The groove of the outer diameter is the edge of the fire ring in the factory head gasket. It has no application here.
The o-ring diameter in your head or block deck should be setup with a diameter thats 1/2 the distance between your 2 arrows. It assists in exerting additional clamping force on the existing fire ring contained in a factory headgasket.
