- Joined
- Oct 3, 2012
- Messages
- 11,842
- Reaction score
- 32
One of them handshaker trucks
oops sorry-my bad
Any possibility you have a sensor issue?
For the boost issue? I don't know for sure to be completly honest. I would think not since it was running good before the turbo/intake/wastegate install, but hey you never know. I'm going to play with some tuning some and thne I'm really thinking about dumping to the atmo like Dillon did. It seemed to help his truck out.
A little update. So I'm still low on boost. I have played with about a half dozen tunes trying to see if that would help with the lask of boost. And it didn't help peak boost. Now its not lazy by any means, it lights the chargers like stockers. So now Elite is helping me to get this thing producing more boost. I shot them an email shortly after the build and Tadd was more than happy to help. So now were playing with some stuff and may end up changing up the gate setup if it still doesn't respond the way we want. I really have to give Nathannial a huge thank you for working with me and doing everything he's been doing for my truck. So I hope we can get it to respond the way we want it to:evil! And I also have added a few new parts, correction I have bought a few new parts!LOL My truck decided to develop the leaky radiator syndrom. So with a little research and a phone call I decided to get an Alradco radiator. And along the way of reading on PSA I also "HAD TO BUY" the Alradco intercooler. And this continued reading also lead me to hit up Brenton at Side Action Diesel and get his fuel bowl delete kit! Once I get the radiatoe and intercooler I will be putting them on. But I will be waiting to put the fuel bowl delete on untill I get a fuelab lpfp. A big thank you to everyone who has helped me out on this build so far. And thanks PSA my bank account HATES meLOL!
You know I am no expert on these matters but I got to thinking about this a little and since it is free to try with MCC, maybe this would help before you re-route the gate...Since these are not drop ins, I am not sure how the exhaust air is routed, but I thought I remember someone saying the up pipes feed all exhaust air to the HP turbo first and then all of that goes on to feed the LP turbo. If that is case, you might want keep your aggressive program the same down low to aid in spool up, but around 2250 RPM or so cut the vanes back sooner. In other words, get them to 5% shortly after hitting that RPM at WOT. In theory, this may help you keep the air velocity up that is coming to the LP turbo to drive it harder. Again, I may be way off on this, but if that is how the plumbing is setup, it might be worth a try. Oh yeah, based on my past experiences with MCC, you might have to actually lower the EBP tables in the same RPM ranges where you are dropping the vanes to get the vanes to go to their desired position. I base that last thought on the fact that when I first tried to do an exhaust brake program, when I just adjusted the vane tables without adjusting the EBP tables, it didn't do anything....but if I adjusted the EBP tables without messing with the vane tables, the exhaust brake works. That make me think the computer is basically following the EBP tables and those tables over-ride the vane tables. I had also experimented with trying to reduce my EBP tables to lower the EBP at WOT and found that lowering the EBP tables didn't do anything at WOT. I assume that was because at full fuel, my setup couldn't keep the EBPs in check without cutting the PW which the computer did not do on its own (it still followed the PW tables even though the EBPs were outside their desired.
I have played with a lot of the desired ebp tables. In my experiences the computer seems to follow the desired tables and uses the vane position tables as a back up reference once the desired can't be achieved. But I'm no expert either! And the exhaust does route the same as it does with stock chargers(hp-lp-down pipe). So by me making a higher ebp table it causes the hp charger to spool faster while developing more drive pressure for the lp charger. With that it "should" drive the lp harder(in theoryLOL). So with keeping a very agressive ebp file with it dumping the extra exhaust energy to the lp charger it should drive it harder than I was able to before(I think). Even with the hp having a modded turbine I can still get the ebp in the mid 70's in the high rpms. Now with the gate dumping off that excess say 10 psi of bp to the lp it should really help it to come alive!
Here ya go Brett! This is from a stop starting out in second(1 on stick) and going part throttle to 3rd(because I just dumped a grand into these tires last month) and going through the gears to 6th shifting easy not trying to really fly through the gears.
http://s1322.photobucket.com/user/g...rt=3&o=0&_suid=139016156333105777882916177304
That thing is WICKED!!!! F#ck the HP, just the sound of that turbo makes it worth it!!!!
LOLThanks. I think your 76 well be putting down better power than mine. At least until I get mine figured out maybe it just wants more fuel haha. Did you ever get a temp gage on your transmission?
