Pro Stock Powerstroke Mustang
BOSS450
Concord, NC
probably be easier to put a waste gate on the compressor side to bleed off boost in that case. Ive been that done and it makes it easy.
With the 150psi overall and 60 psi low pressure you high pressure will be pushing 90 psi.
Now would you not be worried about overspreading the turbos waste gating the compressor side?
ChattyCathy
That's not how it works :) Plus if they are built to run there they would be on the map and be just fine.
Cutting-Edge Diesel
Newkirk, OK
anything I do that will effect how the motors runs gets ran threw hypermax. they have spent years developing this motor and countless dyno pulls with it.
but I asked about turning the motor down and they recommended just running my throttle stop and just not go WOT. Because if we change the fuel we have to change all the nozzles in the water injectors.
ChattyCathy
Dang. That will be fun to get good data on.
bigrpowr
<How I Fly
Administrator
Hyermax makes like 3000hp in their 466 stuff...don't think i'd question their suggestion
well this motor probably wont make 2000 with this turbo setup . but I would not consider going against their recommendations. ben only made 2400 on the engine dyno with (3) hx82's .
Cutting-Edge Diesel
Newkirk, OK
No this motor is no where near 2k the way it is set up right now. We don't have it maxed out running 110% we left room too improve later down the road if we need to
Blowby
uuhhh no!..... Try 17.71 psi at sea level.
Can't wait to see it make a few passes!!!!
swinky
Eastern, Nc
What kinda times would this thing hypothetically run with a good full power pass? 7.xx in the low 200s?
Rodslinger
Lake Havasu City, Airidzona
Our Outlaw 10.5 car weighs 2110 with right at 1700hp.
1.01 - 1.05 60' and 6.80s at 210 mph.
I don't know what the stanger will weigh but I'd say it should be really close to that. It's looks like it's pretty aero and if he can keep the weight off, is should blur his vision till about the 100ft mark!
