Engine is out on a stand, getting cleaned up, new oil pan, HPOP, fuel bowl rebuilt, new water pump, pulleys, tensioner, glow plugs/relay, manifolds, up pipes, paint, etc, the works.
I can't decide if I should pull the injectors and install new o-rings.
Part of me says "don't mess with it, it's fine." part says "you don't want to do it in 20k miles with the engine in the truck, do you?"
Engine is original PMR motor, had 85k when I bought it has 135k now, no issues and runs very strong.
So....should I change the o-rings? Or just let her be? I already have them "in case" 8 sets of Allliant o-rings from Riffraff.
Thoughts?
Thoughts?
