Problem with ipr/ injectors
jrex2506
Ok rebuilt everything, just had injectors gone thru, 190/75s. Mt problem is at 55 mph, the truck kinda sturters, miss. At cold idle but 70 degrees out my ipr is 34/35. The injectors sound a little louder than they should be but I've just had them gone through. so does this sound more like an IPR issue because if I hammer on it then it's fine just when I'm at a steady constant RPM speed.
Sent from my.....i forgot.
Mesa, AZ
Check for broken stand pipes. Seen a couple break and cause weird issues in hi rpm, suppose it could happen lower too...
jrex2506
Ok i just had them out not long ago with the injectors. It was doin this before my rebuild, thats why im thinking ipr but dont wanna throw money at the problem
Mesa, AZ
What all is the same from the build? Icp, pigtail, ipr, pump im assuming. Does unplugging the icp fix it?
jrex2506
New main harness, new pump, icp is good, new pigtail as well. But ipr was replaced 20k miles ago but was sitting like 5 months while i got funds for build
