Mods on the truck are 4" downpipe back straight pipe. Full egr delete with elbow, coolant filter, minimax with gearhead tunes, and arp studs installed with all ford gaskets about 8k miles ago. This thing has been driving me crazy with puking and not puking and i dont even know what to do with it anymore. Had a problem a few weeks ago on a highway drive going up and down some hills where a small amount of coolant puked out. Sinister coolant filter had always been garbage and decided that was sucking air as it was leaking which caused it. Replaced with a different filter mount and all seems good. Pull a 9k lb excavator on a 3k lb trailer up some steep grades to test it out and all is good coolant level is normal and it was definitely working the truck a decent amount.
After that drive i take an 8 hour drive for vacation and another 8 hours back without issue. Coolant level looked slightly low just from me not checking it after the coolant filter change so i add some more. Just now got on it a little bit only to about 40lbs of boost on Matts wild shift on the fly tune and i got coolant everywhere. Maybe its the cap? Maybe retorque the studs back down? Im not sure what to do as im getting tired of dealing with this...the truck never even gets hotter then normal when driving. Im hoping i just had too much coolant in but i guess ill check tomorrow after the truck cools down...
