On a recent hunting trip pulling a goose neck (4,500LBS) 150 miles one way my truck started puking coolant i have a scangauge II and my max temps the whole drive was EOT 226 ECT 217 it lost over a gallon of coolant both ways +1 there and +1 on the way back it may have been a little over full on the way there, prior to the trip i hadn't been loosing coolant but had been smelling it in the cab so i replaced the heater core and the problem went away the truck has a no name egr delete kit Gearhead 8k sct tow tune,Stage 2 turbo truck runs fine idles smooth no loss of power starts up great with no smoke I'm just wondering if this is a minor head gasket leak and its only letting out under a load or if the egr delete kit is failing someway any advice to figure this out is appreciated Thanks also i forgot to add i had the Stant cap on on the way there and switched to the stock one on the way back with no change
