Twinjracing
As some of you know a good friend had a E99 with a bad motor. He brought my 95 OBS motor out of the parts truck. I know we have to switch injectors, valve cover gaskets and harnesses over. Also change fuel bowl over and plug the return lines on the heads right. So my big question is the turbo are the OBS and E99 the same or not? Are the pedestals and up pipes the same? Is there anything else I need to know or change.
Thanks JJ
Sent from my shoe phone
Thanks JJ
