Question regarding oil leak..
Ghost1776
Hello everyone, I have pretty much narrowed it down to either my driver side plenum or my high pressure oil line on the driver side. Just cannot figure out which. I don't want to try the soapy water method cause if it's my plenums I def don't want that seeping in.. Last week I tightened up the high pressure oil line but didn't want to over tighten it if that's possible? So basically what I'm asking how can I check the plenium safely and how tight can I tighten down the hp line?
Ghost1776
Anyone know what size that nut is? None of my wrenches fit the dang thing!
psduser1
on the road
I think it 14mm, can't remember for sure. It's a oring fitting, size is #5. If the oring is toast, you'll need a new oring. Just tightening it won't fix it.
Orings are readily available at any hydraulic shop, and maybe even an autoparts store. Just tell them orb #5.
Ghost1776
Thank you so much!!
