dietoremain
I spoke with Bob today, Im excited to get this testing started!
btw I have a stock injector truck.
Not for sale yet...... You can however pay up to be a tester.
Sent from the left lane with the hammer down...
Ok, whose doing this, id like to see what the parameters and cost is to be a tester.
PM me.
I have full access to a new dyno jet that we have played with a couple times with the current set up less the w/m.
First off, on the 100 HP tune we picked up a solid 20 HP with no other changes! On the 140 HP tune, we picked up a peak of 12 HP and almost 20 HP above 2500 RPM. However, this is nothing compared to the fact that the boost output jump from about 30-31 PSI at 3400 RPM to 43 PSI!!
Who is manufacturing it?
sent while trying not to JJ My rods!!!!!!
Short answer, it doesn't work that way. If it only made 20hp more, that's all the power that was left on the table from the use of the stock turbocharger. The gains are probably a combination of a bit more air to finish using whatever fuel might have been left over and the benefits of improved boost:backpressure ratio.Serious question here, just intuitively with no evidence whatsoever to base anything on, it seems like the HP increase should have been much more than 20HP with a corresponding boost increase of 12 psi? From reading you previous threads on your test mule you were right at the 400HP mark with this truck. Using that number, you experienced a 5% increase in HP from a 28% increase in boost? Does that sound right?
That said, I will try to capture some of this when I test the 38R version. Bob and I have been talking about this for a while now, just waiting to get one to test. I don't have a dyno to use, but I do have a 25 mile commute with sections of highway driving that are never interrupted (next to no traffic). I will do before and after logging of the exact same drive (log start/stop locations), at various speeds (cruise control managed) and various loads (with and without trailer). I've got no problem making my 38R surge with my 200/200s, so we can test that too.Second question, I would like to see some results from real world applications such as is there any measurable boost increase while cruising empty, highway cruising while towing, and pulling loads up grades. Since my truck will never see a dyno I would be more interested in these results.
Of course, this may open up the window for more usable fuel, if the tuning and injectors are not already maxed out.
It's all together possible that it would have picked up the same 20hp at a lower boost level, which would yield less stress on the turbo (stock thrust bearing wasn't designed for that much boost), even less actual backpressure and less heat from the compressor. If this compressor is this efficient, it would be interesting to see what the "before" MAT was, what the "after" MAT was, and then turn the boost pressure down via wastegate adjustment to find where the power drops and test again to see what the the new boost, backpressure and MAT figures (which would require testing with a stock turbo again). If it were mine, I'd try to run it at the lowest boost pressure possible to make the power rather than shoot for the highest boost number with no regard for backpressure and temps.
Hey Bill...if you're going to do another test, put one of Bobs easily adjustable wastegate actuators on the stock turbo first. It would be interesting to find the peak HP boost/backpressure/MAT number with the stock combination and then do the compressor wheel switch. See what that same wastegate configuration yields with the new wheel (more boost with no other changes like the first test you did hopefully), then adjust up and down with the new wheel to document the BP/MAT at the same boost as the "stock" turbo as well as the boost/BP/MAT of the peak hp adjustment (the point where power stops increasing). Hopefully that made sense...
What is the timeline on the 38r wheel and testing?
Nice write up!
Bill,
I'm only 30 minutes from you if you wanna give the wheel a dyno go on a stock injector truck.
I have one of the wastegate controllers on my 38r that bill can try on his stock turbo if he wants, also like you said when bill gets the 38r version on my truck I was thinking since people wanted to see some real world Info he can hook his trailer up with his truck on it to my truck and drag it up and down the interstate some and around town
