Reaching for 600hp but cant get there...help
madman1234509
mayfield, ny
I wouldnt be surprised.... Many 6.4s, esp ones with moderate or high mileage on them wont maintain rp with a full out race tune. It could also be the transmission, or even a boost leak by the sounds of it, its hard to say. Wouldnt hurt to do a leak test.
MaineiacF250
I just went out and did a half a dozen WOT runs and the lowest rail pressure I saw was 24780 at WOT for good 1/4 mile and would build to 54-55lbs of boost
08BIGRIG
WI
When did you purchase your steed speed manifolds? I have tested them the first go around and my truck lost a bunch of power as well as torque. If you have the first set of these, I have no doubt that is the issue.
B585Ford
WV
no TC slip noticed and will do a boost leak test later in the week. I appreciate all the help
If you have a DD, you can monitor TC slip. With that big of tires and a stock tranny I would think that could be an issue (along with a leak).
08BIGRIG
WI
I purchased the manifolds in December from Rudys
I am willing to bet that this is your issue. I bet if you ditch the steed speeds and went either back to stock or with 6.0 manifolds and custom up pipes you will see a good increase. I was down this same road last winter.
bigrpowr
<How I Fly
Administrator
i recall hearing something about this steed speed issue.
madman1234509
mayfield, ny
If you dont find anything boost leak wise or transmission wise I wouldnt hesitate to sell your up pipes andmanis and get stock, or 6.0 manifolds
08BIGRIG
WI
Was it not said they would replace them for the ones sold before the v2 came out...
If it was, you still need to get new up pipes because the flange will be different from the old steed speed to the new ones. Personally, I would ditch them all together and go back with stockers or the 6.0 manifolds and up pipes.
