rear leaf spring help!
teambluemxer
medina ohio
my packs on boths sides have decided to fatigue and break.... i hve a 2000 f-350 xlt CCsB 4x4 offrd packg. SRW with the 7.3 what springs can i put on her
TARM
Do you have any pictures of these broken ones?
How were you driving that thing or loading it to break both spring packs? The only time usually is way over loaded or if you try offroading or try to catch some air. Some combo of that.
I woudl just go to a salvage yard and pick up a pair from a low mileage truck. I can find a number of packs with 60K on the for $100.
If you spring packs are done my bet is you are in need of new shocks and sway bar bushing. Maybe some new bump stops up front.
DcMoore
Amarillo, Tx
Call super lift you can get a rear set for about 350-400... I got the rear springs when I did my lift, screw the blocks.
Mtack
Pomeroy, Ohio
The #4 spring breaking is very common on these trucks. You can order one from ebay and most spring shops keep them in stock. I have changed two of them in the last month.
