Dieselboy.
Again Im fighting with an oil leak from the back of the motor. Believe the pan is warped from the core engine. I found that leak from when I installed it on the driver side rear corner.
However, after pulling the motor, the insepction cover and starter rear main area behind the flexplate is covered in oil.
I filled it extra full on the stand with it tilted towards the back to see if I can get it to leak but it only leaks from the pan gasket.
I cleaned the back of the motor with break clean. Anyone have any ideas for me to pressurize the motor to simulate it running. I dont think the the oil could work its way agaisnt gravity into the inspection cover and then get throw around.
But I dont wanna rip off the rear main seal and cover plate if I dont have to.
Thanks.
Thanks.
