wetnsloppy4x
:doh:
i built the regulated return myself based off a write up on tdg, basically i have lines coming from the back of the heads to an aeromotive regulator and it goes from there to the factory return housing and is tapped in, i dont have pics of mine but here is a similar setup (person i got the writeup from), he used a .125" thick by .5" o ring on the inside to keep the plunger closed, does that sound right? i havent done that yet but will if i need to
pump is stock hfcm
So the front lines are stock? Stock banjo bolts also?
If I'm reading this right, the original person used an o-ring behind the poppet to keep it from opening, but you didn't do that? If that's the case, the stock poppet is opening and causing your pressure issues and your regulator is nothing more than a fancy crossover line right now. You MUST prevent the stock regulator from opening or the aeromotive regulator won't do anything.
