regulated return there ratings
sideswipe7
if you guys could rate all the regulated returns out
there 1-10 10 being best.
cost
quality
ease of install
longevity
performance
if would could you give reasons why you gave each one that rating
Have no experience with others but love my driven diesel one. Easy to install great directions and performance hasent been on long but no problems
Powerstroke 7.3 work in progress !!!! Yfz450 intake exhaust jets + lots of other goodies!!!
Vw jetta tdi straight piped 55 mpgs!!
golfer
We quit making our own, since Driven Diesel's are such high quality.
IMO, there is no equivalent
CSIPSD
Bend, OR
Ditto...
There is no better system on the market.
Bowl delete...
http://www.strictlydiesel.com/p-266...-delete-regulated-return-fuel-system-kit.aspx
Standard...
http://www.strictlydiesel.com/p-2663-driven-diesel-standard-regulated-return-fuel-system-kit.aspx
sideswipe7
so out of all the kits out there this is the one that is best quality
and cost for what you get and ease of use. so how long have
you guys been running this kit.
CSIPSD
Bend, OR
Linked above...
I had a Strictly diesel kit about 8-10 years ago... I installed the bowl delete kit about 5 years ago... Not one single issue...
CSIPSD
Bend, OR
wow now that gives a good reputation for reliability
and long lasting ability.
Dennis was ITP diesel before he was strictly diesel... His first fuel system was one of the first, and did not change until about 4 years ago with some updates...
The quality, fit and function has not yet been matched.
Are there cheaper kits, sure... Irate is one of them. It works, but its not as refined nor does it fit as well...
R.J.
Maryland
Another vote for strictly diesel kit. I installed mine about 3 years ago and the fit was perfect. No tweaking or modifications needed for a perfect fit first time.
sideswipe7
How long did install take and did you run into problems
loosening bolts. What do you guys think of those banjo
bolts.
For me install took a few hours but I was in my driveway with a box of tools. No real problems cover everything u need to remove with on blaster should come off fairly easy. I don't reccomend them unless you already have your engine out is a big pain for little gain.
Pb blaster*
bruce
Middle east
Di's kit works no doubt, it just doesn't fit or look as clean as Dennis's. Strictly's kit looks OEM it fits so well
