Retro Solutions Digital HIDs ordered
cfdeng7
CT
Slight problem. Every time I hit a bump the lights go out. Traced the problem to the relay. I wrapped electrical tape around it to get me home but it did't work to well. Any suggestions?
New relay, also are the wires going into the relay loose or anything
QtrHorse
As stated above, it's either the relay or loose wiring. Sometimes you can get a relay with loose contacts in side or it's just the wire connections on the relay. You can get another realy cheap at most any auto parts store.
PTSUPERD
Yes. They are in....but one of my ballasts are apparently bad. Uggg...
Before it gave up:
TxFireman1972
Beaumont Tx
Might as well order an extra ballast or two as well as bulbs, they go bad. And NOBODY locally will sell you just a bulb or ballast.
PTSUPERD
Ballast is coming Next day Air from RS. Thanks Jason and Todd for your customer service.
PTSUPERD
I personally have no experience with DDM. Maybe somebody else can chime in.
