Riffraff Diesel Coated Pistons 6.4
Hey guys going to be slowly adding products to our section here so you guys can see what we offer and some of our new products that will be coming out soon.
One of our new products that we have come out with is our Coated International pistons with our own unique coatings. You have three options for coating combinations, Extreme Thermal Barrier Gold Coating for the piston bowl and face to eliminate hot spots and to allow a faster/hotter burn, Dry Film Lubrication coating for the skirts to guard against galling and eliminate friction, and the underside of the piston is coated with an oil-shedding thermal barrier coating to help return the oil back to the sump and allow the oil to soak more heat from the piston while doing it.
http://www.riffraffdiesel.com/international-heavy-duty-ceramic-coated-6-4l-piston-set/
