Rough start then dies when warm
strokethis_06
Got a 6.4 that starts and drives fine. No codes. Once shut off warm if you try to restart it it fires up and runs very rough for a few seconds then dies. Restarts fine if you let it cool down. Truck is ******d and tuned. Otherwise stock.
Sent from my SM-G935V using Tapatalk
Mesa, AZ
Is there coolant in the secondary system, is the pump for it running, and is there flow? Sounds kinda like hot ass fuel to me. Also check frp voltage koeo, seen a bunch of those sensors go bad.and theyll sometimes only act up hot. Had to drive one third gear foot to the floor on the highway for a while to get it to act up. Never stalled but bucked like mfer.
strokethis_06
Got it. Swapped out frp sensor and harness. Thanks for the suggestions.
