Rumbling at 60mph
superduty4x4
Newport, WA
Running around in the truck this weekend I noticed a rumbling that was most prevalent at 60mph. It's barely noticeable but it is there, nothing like a bad u-joint does. I replaced the clutch about 1k miles ago and at that time all the u-joints were fine. Front wheel bearings have been recently repacked. It seems to be coming from the front end but who knows. Possibly a bad rear wheel bearing? Any other ideas?
rear end?
undo the rear u-joint and check for pinion play. or else jack the back end up and use a doctors stethoscope to isolate the noise
superduty4x4
Newport, WA
rear end?
That's kind of what I'm afraid of... if it is the rear end (or heck, could even be the front end) I might just start hunting for a set of 05+ SD axles.
look no further. i have a set of 05 axles sitting here on a rolled truck. i can also make you a deal if you need additional suspension parts to make them work. pm me if you want.
Tom S
I think I would recheck those front wheel bearings and if you have locking hubs make sure they are free.
superduty4x4
Newport, WA
Front wheel bearings were fully packed (both the little one up front and the big one in the back of the hub) within 100 miles. Locking hubs seem to be functioning properly but I'll check them again.
superduty4x4
Newport, WA
Fawkin kids... one of them must have locked my hubs in at some point. I haven't used 4WD since last winter and when I went out to check this weekend guess what... both hubs were locked in. Didn't get it up to over 60 but the problem seems to have gone away :doh:
