Beings it has an 87mm turbine, not quite the best. An 80/96 or 92 would be better. But if you planned to run stock fuel forever with the bigger exhaust housing, it could be a quick spooling fun set up. I would get in touch with Craig.
Good luck with the new set up. I want specs when its done. If you really are doing tripples i'm stoked because I really wanted to try it for myself before I did my current set up.
