SALE: Thanksgiving, Black Friday, Cyber Monday SALE!!!
retrosolutions
2012 HOLIDAY SALE
Starting from Today and all through until the end of Cyber Monday Retro-Solutions is running the following fantastic deals! That's right... a whole week, November 20th through to November 27th!
15% Off regularly discounted store products, including:
- 35w DIGITAL HID kits
- 55w DIGITAL HID kits
- NightVision HID kits
- HID bulbs, ballasts, wiring, etc.
Use Promo Code: HOL2012
* available for use on www.retro-solutions.net only!
10% Off LED replacement bulbs, on any order over $50, including:
- dome/map lamp bulbs
- brake/indicator lamp bulbs
- even our famous CREE reverse bulbs!
Use Promo Code: LED2012
Offers can not be combined with any other current offers or with each other on the same order. For a limited time only, sales are not retroactive, no rain checks issued, and limitations may apply!
All text, images, and other media are protected under copyright 2012, do not copy or post without direct written permission from Retro-Solutions, LLC​
retrosolutions
So how much for 2005 f250 digital 55w 6k high/low the same for the fogs.
Sent you a PM for that, but please make sure you got it. We sent that and a reply to the thread previously.... and well, not sure what happened to the thread reply!
Extended Power
Trying to order online.
I have a set of Recon smoked LED tail lights.
I would like to order the CREE reverse lights for them...do I order the "Top 5w LED only", or the "Top LED with radial LED"??
Just double checking the part numbers I require:
For the license plate, running boards, and Autometer Phantom gauges, Part# 168
For the interior dome lights, front and back, Part# 578
For the small map lights that are on rocker switches which are right on the dome light housings: Part# 912
Thanks, looking forward to ordering these ASAP!!
Extended Power
One more set I would like is for the stock 3rd brake light assembly.
Bulbs for the brake light, and the cab lights on both sides.
Thanks!
retrosolutions
Thanks!
If the Recon lamps use a 3156 type bulb, by default there go with the "radial" version of the CREE bulbs for best performance.
The 168 bulbs are part of the T10 series of bulbs:
http://retro-solutions.net/product-info.php?T10_194_168_158__2825_5_LED_Wedge_Bulbs-pid686.html
The interior dome lights are 578 and commonly such as well:
http://retro-solutions.net/product-info.php?High_Power_578_LED_festoon_Bulbs-pid692.html
The 912 bulbs are a T15 series bulb type, also commonly listed as 921:
http://retro-solutions.net/product-info.php?921_912_906_T15_LED_Wedge_Bulbs-pid689.html
Its also the T15/921 for the 3rd brake light (same as above) and the cargo lamps, although for the white cargo lamps there is also a CREE bulb selection:
http://retro-solutions.net/product-...5_5W_CREE_LED_Reverse_Wedge_Bulbs-pid787.html
Extended Power
Trying the "PSA" code at check out, but no discount shows up.
retrosolutions
The LED bulbs are not discount eligible product unfortunately, so the PSA code is working but does not apply to those items in your cart there. Sorry for any confusion there, as this thread was for a seasonal sale that ended early last week, not sure if that's throwing you off there.
Extended Power
Yeah...pretty much...
I'm gonna order them all today.
Hope I didn't miss anything...RED led in the stock third brake light center, correct? (so it doesn't show pinkish)
retrosolutions
Right, a white bulb behind a red lens would only give you a more pink lower output.
