GO BIG OR GO HOME
Had a customer complain about a "slight" noise coming from the rear of his truck. Took it down the road and the rear end sounded like a tub grinder with a steel plate in it. I pulled the diff cover and only got about a half a quart of fluid out which stunk to high heavens like burnt sulfur. Had the consistency of water but not much metal. A little bit of very fine metal but nothing out of normal range. Cleaned the gears up and this is what I found.
The metal on the plug is a little excessive but other than that no abundance of metal in the differential itself
sent while doing burnouts somewhere in the country
