Boy I'd love the answer to this one too. Mine does exactly the same thing. Passenger seat works great but driver seat does nothing but the light comes on
I had the same problem with me 6.0
I was told that there was a wire in the seat that was prone to break and needed to be fixed. It required removing the seat and bottom cover. I never got around to doing it but I heard this from multiple people. Just my .02¢
Sent from the wild blue yonder....
Same on my Ex
exactly. worst case is the element needs to be replaced.
Is just the piece that needs replaced available from ford? Or do you have to get the whole thing?
Tasca auto parts sells the element. most the time you just need to solder the small wire back together with a heavier gauge wire. Once you do the drivers side you might as well do the passenger side it has the same under sized wire.
Nothing crazy the original wire is tiny. 16 gauge would work fine. theseatshop.com has a very good video on removing the bottom seat pad and replacing it. Worth watching before trying to tackle the job.
