Secondary HPOP resivor feed
V-Ref
9 miles high @ 550 mph
Fed off the oil cooler/filter assembly on my truck.
79jasper
skiatook, Oklahoma
Could be way off base here, (still a newb), but what about plumbing in a kit like the NUC bypass oil system that was supposed to run back up to the oil fill neck and just plumbing it into the hpop res. That way it is already set to the balance point you need without depleting the oil flow, but still gives you more flow to the hpop, and it would be freshly cleaned. ? Just a shot in the dark here, professionals, would that be a good idea?
Far as I know, that won't work, since the hpop reservoir is pressurized.
The bypass filters need a free flowing return.
So who is this mod useful for, big oil and injectors? Or everybody?
Sent from my USCC-C6721 using Tapatalk
V-Ref
907Dave isn't on here much nowadays...but I can give no higher endorsement to someone that knows there way around a 7.3. Real world -40F ambient temps, has been through several motors the hard way, tunes his own truck, DD a compound 7.3 for years....super smart and just a genuine good guy.
PM him.
