stroker221
Just picked up a used k16 pump said to be good. (Engine it came off of done a cummins swap bc cam got trashed. So should I send this off to have it checked over/rebuilt before throwing a belt around it for a dual fueler setup? I don't worry about the front seal leaking, I worry about the pump trashing and sending metal shavings through injectors. Thoughts? Would most likely send off to Remanautoelectronics
