Short block assembling, tools?
78f100
Bonifay FL
If you marked it and put it back exactly like it was your fine. I don't think both were 180 out, i could be wrong but if you had rotated the engine over a full rev it would have lined up like it's supposed to. You didn't do it the correct way but ended up with the correct results. I don't have the tool but I mark the adapter above the timing mark and go off that. If not it's easy to have it 1 tooth off.
