Show room clean out. Powerstroke and Cummins parts
DIESEL SHOP LLC.
GRISWOLD, CT
All parts are new unless noted.
*USED* Spartan tuner for 08-10 Ford 6.4 Its unlocked and ready to be loaded on your truck. 1325$ Shipped
*USED* SCT Xcalibrator2 hand held box. Ready to have your tunes installed.
200$ shipped.
SCT Livewire EGT probe kit. Part# 9617 75$
H&S TPMS module kit. Part#709913 08-10 6.4 used for turning off tire press light with aftermarket tires. 100$
H&S EGT probe kit. Part# 709401 This add on will work for Power stroke, Duramax and Cummins. 150$
H&S EGT probe kit. This kit was made for the 6.7 Powerstroke. Part#302202 40$
6.7 Powerstroke cat delete pipe. just the pipe. 50$
7.3 hypermax down pipe for H2 kit. 75$
BD KDP kit 98-02 cummins 100$
BD KDP kit 94-98 cummins 100$
Industrial Injection 5.9 BAG O PARTS cp3 kit. 320$
Aluminum cummins intake plates by Crazy Carl. 12, 24 and CR 200$
Cal-tracs for 2WD SD FORD $400. box has been opened but never installed.
If you have any questions shoot me a PM or just call the shop. Im sick of looking at all this stuff when I walk threw the show room. I want to make room for new. Package deals can be made as well.
James
Diesel Shop
860-222-3040
Magnum PD
VA
What size is the flange on the down pipe and diameter of pipe? Need one for HX55.
DIESEL SHOP LLC.
GRISWOLD, CT
Will the sct livewire egt gauge work on a livewire ts? If so ill take it.
Yes it should work. It comes with the all the parts and the cable to plug it into your cord coming from your OBD 2 adapter. If you have any more questions or would like to buy it feel free to call the shop or PM me.
c.jank
Houston, TX
Interested in the H&S EGT probe kit. This kit was made for the 6.7 Powerstroke. But i sold my DPF.. what are the chances of getting the proper sensor?
DIESEL SHOP LLC.
GRISWOLD, CT
Unfortunately this kit is to be used with one of your stock sensors but if you want we can try to find you a sensor I know someone with a setup sitting in there garage.
DIESEL SHOP LLC.
GRISWOLD, CT
Caltrac? Can it be used on with a lift kit?
This kit was bought for a 2wd setup but I cant actually tell a difference between a 2wd a 4wd kit. and we have run them on a truck that I believe had a 4" lift. If I remember correct all we had to do was drill one new hole in the kit because of the lift. Hope this helps.
