Single turbo info
Cknox121
Augusta GA
Thanks for the input guys.
Honestly think I didn't have them tight enough. I bottomed all the springs out on the clamps. Holds for now.
I'm thinking it has something to do with the ways the kits made. Not bashing it, I love how it looks, but it must take h&s custom charger to take full advantage of the kit seeing as it's a non divided housing turbo that comes with the kit.
I'm sure keeping the exhaust divided surely helps with a off the self s300 turbo.
Emailing Zane and see if I can get him on the phone to go over a few things before I throw more cash at it.
Be expecting a call as well Morgan. Would like to talk to you about this as well.
Thanks for the video Mike! Your trucks one of the main reasons I went single turbo lol. Such a beast! Post specs in here if you want too. Give other guys ideas.
CT9AIX
MA
Not that I have very much input on this subject yet, but I've had much better luck in the past with the t-bolt clamps that don't have the springs. Hopefully you get this baby up and running soon so we have some tire carnage to watch! :thumbsup:
Cknox121
Augusta GA
Guess I can think Will for these ****ty clamps then lol.
Hope to have some wot runs in a few. Charging go pro.
Radioflyer
Agreed. I threw the spring clamps in the trash for t-bolts. Hope to see some good videos Cody!
Cknox121
Augusta GA
Boots are holding. Reloaded hd300 set low boost fueling to 5, spools like a champ. Can't hold it back past 7-8psi.
Overall boost will not climb past 36-37psi
Cknox121
Augusta GA
Do you have a wastegate? There's gotta be a reason why it doesn't make good boost. That or the turbo isn't right.
No waste gate, not signs of soot or leaking up pipes.
I'm thinking turbo is fubarded
SEABEE08FX4
Montgomery TX
You should have more boost than that for sure, when I ran a 66 it would get over 60 PSI on some runs. You have to have either a boost leak or a pre turbo exhaust leak.
Pressurize the intake side to 15-20 lbs and see how long it holds it for. If it holds or bleeds down slow then you know you have an exhaust leak some where. You'll need to make your own boost leak detector, pretty simple to make with just stuff from the hardware store.
Cknox121
Augusta GA
Defidently seem's like it's getting hot pretty darn quick..
Stays about 1300 till it hits od
I seen a thread awhile back on doing the test. Will have to find it.
Thanks
Mine barely touches 1400 wide open
Hmm interesting for sure. I'm going to have to dig deeper that's for sure.
ChattyCathy
Thanks
Soon it will all be ok.:pimp:
Cknox121
Augusta GA
Soon I hope. I need to quit spending money on other things and focus on truck funds. Its about to be my birthday so YOLO!
Oh and blowed the double clamped boot off tonight on a 0-130ish run
Data on a 0-130
Changed to Gearhead "2" tuning
Max egt according to mini max - 1555
Max oil temp - 207
not sure on boost, some where around 37-38 psi. Still can't understand this?
Next mod will be superglue on the boot, possibly new turbo, and some traction bars. I can feel the axle rolling.
