Slam door, kills engine
Dslfumes
Nederland, Texas
Ok, here's a weird issue that has me stumped. If one of the front doors on my wife's excursion is slammed hard the engine dies. If restarts and runs fine. It has happened three times now. I replaced the battery cables with a new set and everything is tight. Any ideas?
under pressure
Not funny.
My radio and p/w shot off sometimes when the door is shut.
Then in a bit I'll here a click and they turn on. Weird.
TARM
Your lucky it did not fry the chip and PCM at the same time. Glad you got it figured out.
Dslfumes
Nederland, Texas
Wasn't the chip being loose. Pulled the chip and it did it again when I hit a big bump. Gonna check the PCM connection when I get off work.
i had to have my pcm checked out cuz mine was doing the same thing.... the connections where the chip goes in where to wore out and needed built up so they built it up and no more problems... but with the chip out and its still doing it then prolly bad connection internally.
